Messing Around With a set of F-500 Gauges...
FoMoCo
Post by FoMoCo »
Hey all I dug this out of the wood work. They had been lost during the move and recently found all the parts. I powder coated the surround and was thinking about using this old tach my Grandfather gave me. What do you think?
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
you powder coated it? it looks chrome to me. or did you get it powder coated chrome? can you do that.
kaptnkaos
re: Messing Around With a set of F-500 Gauges...
Post by kaptnkaos »
Hey FoMoCo
I'd go for it... it matches good
Is it a mechanical or electric one?
most of the f-500's and up had mechanical ones...
If the tach is a mechanical one, you'll have to get the matching dizzy and drive cable for it to work.
Since the big bumps mostly had FT series engines instead FE's that may not be possible.
If it's electric... man you got it made
KaptnKA 8) S
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Just my opinion, but even for a daily driver you'd probably want a tach that reads a little higher. The big trucks didn't turn high RPM's, so a 4-grand tach was all that was necessary. However, even if you don't plan on hot-rodding around, I'd still suggest at least a 6-grand tach. Redline on an FE is around 5K, so it's probably better to have it and not need it than need it and not have it...know what I mean? ;)
FoMoCo
Post by FoMoCo »
I powdercoated this one myself. The powder is a single stage chrome mix from Pendry powdercoating. Being that Grandpa worked on semi trucks all his life, I'd say this gauge was intended for a deisel. It is an electric gauge though. I was thinking of using it if I did the 300 swap but that's not looking likely.
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
it certainly looks good. i dont know if you need a tach do you? do you plan on hot rodding like kieth said?
seattle67
Post by seattle67 »
Sheesh, I look around in my closets and all I find are clothes that used to fit me, but are a little tight now :roll: and a little dried up present the cat left for me. But to date, no cool Ford parts!
Dan
1971ford
Post by 1971ford »
well i found a few ford stickers. that was pretty awsome. i wish i could find a nice running 4x4 bump laying around my room somewhere.
-Ryan
HRDROKN
Post by HRDROKN »
1971ford wrote:well i found a few ford stickers. that was pretty awsome. i wish i could find a nice running 4x4 bump laying around my room somewhere.
Did you check under the bed? :lol: :lol: :lol:
'69 Ford Cummins Crew Cab... Built 6BT main & head studs, ported & oringed head, springs, Ti retainers, marine cam, tweaked P7100, 4K gov kit, NV4500 w/1.375" input, Southbend 3600# DD clutch, NP271 w/SYE, D60 HP front, high steer, 16" coilovers & 4-link, D80 w/disc rear, 4.10's & LSD, spinning 38" x 14.fiddy's on classic slots..... more coming!
http://www.fordification.com/forum/view ... hp?t=23267
Ranchero50
Post by Ranchero50 »
That's interesting, the box says 0-6000 RPM. Wonder if it was a swapped out unit? I'm running a 4000rpm tach and it worked fine with the 360. 3k was about as high as it would rev anyway, I usually shifted between 2000 - 2500 rpm. With the diesel it's gonna be perfect.
Jamie
