Hey Everyone. I know that this isn't in the '67-'72 range but I figured that this problem that I have encountered is a basic wiring mistake.
I decided to exchange the stereo with a newer one. I had made sure that the stereo was getting power before I was going to connect all of the speakers. Well, the unit had turned on just fine and figured that it was good to go. I then decided to crimp all of the wires to their appropriate places. But now the stereo doesn't turn on, the clock on the dash doesn't work, power locks don't work, and the interior light doesn't work.
Did I blow a fuse or is there something more serious that I need to look at? Any input will be greatly appreciated.
Thanks,
TOWENS
'95 SRS Mustang Stereo Wiring
- towens
TRAVIS OWENS
"Never argue with an idiot; they will only drag you down to their level" -Anonymous
1972 F-250 CAMPER SPEC: SPORT CUSTOM 360 2WD; C6
1995 Ford Mustang V6; C4
1981 Honda 70c Passport Cub
1982 Honda Trail 110
- lightning_msd
re: '95 SRS Mustang Stereo Wiring
everytime i install a stereo without disconecting the battery, garenteed i blow a fuse, that many things shut off, then ya its a fuse, its because when you start testing wires for power, i usually accidently rub a couple together and poof thats a fuse...
1967 F100 "Lexxi" 352
http://www.fordification.com/galleries/ ... ?album=482
- towens
I have some bad news..... I had driven the car for the first time after I had encountered this problem and now the speedometer doesn't work as well; it did before. Would this also be connected with the fuse? I am still learning wiring and am open to learning all that I can.
Thanks,
TOWENS
Thanks,
TOWENS
TRAVIS OWENS
- lightning_msd
yup i had that problem with my girlfriends 96 aerostar, it was just a fuse...
- towens
Thanks for the reply. It was all controlled by a 10 ATC fuse. Guess I am used to working on things much older.
TOWENS
TOWENS
TRAVIS OWENS
