Mystery under dash connection
mjhaltom
Post by mjhaltom »
Does anybody have any idea what this is supposed to connect to? It is behind the instrument cluster on the left side. It is two brown wires. Thanks-- :fr:
1989 Ford F150
1966 International Scout 800
1953 Chevrolet Tin Woody
mjhaltom
re: Mystery under dash connection
Post by mjhaltom »
Correction--4 brown wires going into one connector. The gold colored metal at the bottom of the PIC is the headlight switch.
1989 Ford F150
Thunderfoot
Post by Thunderfoot »
I believe that is the connector for the wire to turn on the Roof / Marker Lights relay if you had roof lights. It would be (U) in this diagram http://www.fordification.com/images/sch ... arkers.jpg
I know it doesn't look the same in the diagram but the colors are correct, you could put a test light on it to confirm...
