Details of the horn switch on a 'three spoke ring' steering
pdr1966
Post by pdr1966 »
Does anybody know of some diagrams showing what SHOULD be in there to make the horn ring/switch work?
My truck had a switch taped on top of the column, I figure I can fix this properly if I know what it is SUPPOSED to look like
PEte
69twotone
re: Details of the horn switch on a 'three spoke ring' steer
Post by 69twotone »
I know the Dennis Carpenter catalog shows all of the parts anyway. Here is a picture from the site that popped up as I was typing a reply. :fr: :2cents:
http://www.fordification.com/forum/index.php
69 f100 Custom cab Two tone maroon and white
Looking for a steering wheel with the horn ring, maroon or any color. PM me
1971ford
Post by 1971ford »
hey 69twotone,
that link is of the FORDification index.
I just ran into the same problem. i have a 3 spoke wheel and there is a spring, and two brass parts that are very small. i need to check if they are broken.
-Ryan
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
You should have one of these brass contacts:
..and it should go in here:
That brass contact rides against the ring on the bottom side of the steering wheel:
1971ford
Post by 1971ford »
thank you so much keith!
that is exactly what i needed. now i know i need a new contact assembly since the wiring stuff in the spring is mostly gone in mine.
where would the best place to get that be?
-Ryan
you can try the junkyard but you can get it from any of the vendors i think.
pdr1966
Post by pdr1966 »
SUPER PICTURES!
Thanks the detailed photos were exactly what I was looking for.
A while ago I drilled and taped a stud in to the wheel to flip the turn signal release, I'll have this off soon to re-center the wheel, and I'll get a horn contact in at the same time.
THanks
Peter
sideoilerfe
Post by sideoilerfe »
There are two of those spring/wire pieces. One goes under the steering wheel and makes contact with the bottom of the steering wheel and the other touches the horn ring. When you push on the ring, the center of the ring grounds to the column shaft and sounds the horn.
Most pepole don't know of the second button. There is also one under the steering wheel on the '71 and '72 trucks.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
