How To Safely Remove Horn Button???
Mooosman
Post by Mooosman »
Hi guys,
I'm trying to get a steering wheel off of a spare column I have. It is the 2 spoke wheel, like on 71-77 models. The wheel has a nice horn button/pad assembly, so I would like to get it off undamaged.
My only convern is that the plastic is probably brittle.
Does anyone have a procedure for getting the horn button assembly off without breaking it?
Nick :?
1972 F-100 Custom SWB
basketcase0302
re: How To Safely Remove Horn Button???
Post by basketcase0302 »
Nick,
If I understand what you're asking....
There are two phillips head screws on the back side of the steering wheel and it comes right out.
jor
Post by jor »
On mine (67 and 68) you just push the horn button straight down and give it a quick turn counter clockwise.
jor
kaptnkaos
Re: How To Safely Remove Horn Button???
Post by kaptnkaos »
Mooosman wrote:Hi guys,
Nick :?
Hey Jor...
Mooosman's talkin' about the newer style... not the pre '71 style...
Jeff's got it spot on...
two screws from the back hold the pad on...
I can't remember if there's a wire that connects it or not...
but you will be able to tell after getting the screws out.
KaptnKA 8) S
Mooosman
Post by Mooosman »
Got it out, I thought there was more to it than that! I thought there were some plastic clips in place that held it in, in addition to the 2 screws.
What I am concerned about now, is that the little spring-loaded pin that contacts the back of the steering wheel (where the juice goes through to the button) is about to come out of its little holder, because I have a 3/8" gap between the wheel and the column. If that little pin comes out, I have no horn :eek:
For now, though, I got it put back together and working. :thup:
Nick
that is usually the symptoms of bad cab mounts. im not saying yours are going bad. but tyou can adjust the steering column back together by loosening the bolts and pulling the outer shaft up to the bottom of the wheel.
