Removing key switch, headlamp switch, radio & bezel
19FORD69
Post by 19FORD69 »
can somebody point me in the direction of the best possible break down on removing these from the dash without getting pissed and breaking something, please?
Any help appreciated. :thup:
69' F100 SWB -390 cid, Bored, Cam, R/R's, P&P heads, Avenger 830cfm carb., MSD 6AL, MSD Pro Billet Dist., spool, 9" rear, 4.10's, fuel cell.
FORDification
Site & Forum Admin
Site & Forum Admin
re: Removing key switch, headlamp switch, radio & bezel
Post by FORDification »
To remove the headlight knob you reach under the dash and push a small button on top of the switch. Hold that switch down and pull the knob/shaft out. Then to remove the switch you just use a large screwdriver and unscrew the inner bevel retainer and remove the switch.
To remove the windshield wiper switch bezel, I've used needle-nose pliers and flat-tip screwdrivers....but I've never been able to get them removed without boogering them up. That's why you just can't beat the proper tool:
The tool is available from Eastwood for $17:
http://www.eastwoodco.com/jump.jsp?item ... pe=PRODUCT
To remove the lighter you simply unscrew the back lighter retainer from the socket. Hold the socket by sticking your finger in there (be sure you unplug it first!) and then reach up under the dash to unscrew it.
The rest of the knobs are simply held on with a small Allen-head screw, loosen it up with an Allen wrench and pull off, then unscrew the bezel.
19FORD69
Post by 19FORD69 »
Thanks for your help.
basketcase0302
Post by basketcase0302 »
dang Keith!
I always wondered what that tool was suppose to look like! :oops!:
I've "boogered" up more than one bezel before with the needle nose trick!
lasereyes
Re: Removing key switch, headlamp switch, radio & bezel
Post by lasereyes »
What is that tool called? Eastwood doesn't carry it anymore
"Whenever the people are well-informed, they can be trusted with their own government.”
Thomas Jefferson
search ebay for a "bezel removal tool". yo umay or may not find it. you will probably find the one for the ignition switch more than you would the wiper switch. i havbe one 91 bear sent me. its ok. but really should have had the prongs on it longer. i should probably send it back to him some day.
FORDification
Site & Forum Admin
Site & Forum Admin
flyboy2610
Post by flyboy2610 »
If you have an old deep socket of the proper diameter and a bench grinder, you could probably make one.
