Confirmed! They ARE double element bulbs, and as Thunderfoot noted, and the turn signal lights are brighter than the marker lights. With the parking lights on, you can still see the signals flashing. I'd probably see it even better if I replaced my cracked up parking light lenses.
I actually bought some red 14g wire on my way home yesterday afternoon, cut a 3-4" piece, and crimped on some male spade connectors. I then just slid the spade up alongside the two connections I needed (brown and black/yellow). There appears to be enough "friction" there to hold them in place just fine.
It worked like a charm!
The only issue I noticed this morning is that for some reason, the signals refused to flash once or twice for whatever reason. It was not persistant, though. If I put the truck in park and then back in drive, they would work. I don't know that that really did anything, as it may have worked again without me doing that. This is not an issue I had until I installed the jumper. It may be that the connection is a bit loose in there or something, or it could have been a fluke.
FYI, I would not have used 16g or 18g, as that seems like it would be too lite and maybe get hot. And 12g wire seemed like it would have been overkill.
