parking light/headlight question
I read somewhere and can't remember where. That the reason the parking lights don't come on with the headlights is a problem in the wiring and it can be fixed. The question I have is. Is this true and how can you do it. Any help would be appreciated. Thanks.
I've always been crazy but it keeps me from going insane.
When life gets you down remember one thing. Its only a Highway so pull your Hat down tight and just Ledoux it.
- 68F250
re: parking light/headlight question
Did you read that on this board?
Parking lights on with headlights started with the '70 model year for cars and trucks. If you have a '69 or below, they don't come on.
I don't remember. Ive thought about it alot and I don't see no way it can be done without another switch in the wire between the parking light and headlight. without a switch it will turn on the headlight with the parking light and the parking light with the headlight. I hope I didn't confuse you too bad with that.
- mk
Just checked my Echlin book and it says the same h/l switch is used from 65-77. Guess I'll have to look at my wiring diagrams and see which wire is different.
mike
mike
- 68F250
Mike, we got that covered in this thread:
http://fordification.com/forum/viewtopic.php?t=2877
Basically, Ford stopped using the parking light connection on the switch in '70 and tied the front parkers to the taillights.
- bluef250
The switch is the same. The wiring in different. As 68f250 said, its covered in another thread. Looks like the fix is simple.
