single din radio install
69rangerf100
Post by 69rangerf100 »
just wanted to see if anyone else has installed a single din cd player into their truck i have a 1969 f100. i know its going to take alot of fab work any suggestions?
seattle67
re: single din radio install
Post by seattle67 »
Not sure if this answers your question, but I have seen the following information in other posts regarding radio installations.
Quote:
You can install a CD player into your truck's slanted dash by using a Metra DIN radio installation kit #99-9222 for a '75-'93 Volvo. Flip the mounting piece upside down and attach it to the bent-back ears in your dash, which will allow the stereo to sit perfectly horizontal in the dash opening.
(edit) Here is a link to another post regarding the Metra kit: http://www.fordification.com/forum/view ... ight=metra
Dan
Nausea
Post by Nausea »
And if you have $30 and want a post mount radio/tape deck, I just saw one in Autozone :D
'72 F250 Ranger
Disk brakes, PS/PB, 360 2bbl
Current condition : beloved 'beater'
'70 F250 Camper Special
Currently in the shop, totally stripped
Nausea
Post by Nausea »
Ah yes, I just learned also that some 1.5 din units (like an older Pioneer for ex) will mount with the supplied bezel. No pics, but test fitted a buddy's old one and it'll work.
'72 F250 Ranger
Nausea
Post by Nausea »
Sorry! Wrong on my last post!!!! It will NOT fit without some cutting. The bezel and front of unit itself will fit fine, the body of the 1.5 din is too wide by about 3/16" even with the ears bent out of the way.
Although I absolutely hate the idea of it, in order to fit one in, my dash will need some trimming :(
I will say this, the angle and fit of the 75-93 Volvo kit is just about perfect for a 1 din radio though. Just need to find one that is a bit narrower.
'72 F250 Ranger
ltteg
Post by ltteg »
please explain single din and 1.5 din
Ranchero50
Post by Ranchero50 »
This is a 1.5 DIN stereo
This is how mine is going to fit. The wood block is a template for fitting.
Ranchero50
ltteg, for your sig pic you need to put '[IMG]' on both sides of the address.
Jamie
