I have a 1971 F250 with the original A/C. Its in perfect condition, but seems like it has no power going to it. Blower will not go on and the knob when turned to on A/C does nothing.
Question is there a seperate fuse aside of the fuse block like a fuseable link or in line fuse. Any advice or suggestions would be appreciated..
Also the 2 tensioners for the a/c belt has pressed in bearings and the bearings are bad. I removed them and LMC does not list replacements and I do not know where to start to find these? any advice?
Blessings,
A/c unit power and pulley bearings
re: A/c unit power and pulley bearings
I have a was a dealer installed unit - power was fed off the accessory lead in the harness and off of a direct run to the fuse box. Of course from the cab unit there is a lead running to the compressor to engage clutch. And make sure ground is adequately made.
These guys sell mounting hardware and the idler (I've never dealt with them tho) http://www.nostalgicairparts.com/ Let us know if you talk to them!
Have you tried the local auto parts stores for the bearings? Somebody should be able to find a match if you can provide the bearing dimensions.
'72 F250 Ranger
Disk brakes, PS/PB, 360 2bbl
Current condition : beloved 'beater'
'70 F250 Camper Special
Currently in the shop, totally stripped
'72 F250 Ranger
- l1k2gadd
A company that used to sell bearings of all kinds was Miller Bearings. I'm not sure if they are still in business or not, but I believe they were a national company, but I'm not sure.
The bearings usually have numbers on them (some of them I have seen have been on the sides). Like Nausea said, some auto parts stores can cross-reference bearings from the numbers on them (or application if they have the paper catalogs).
going to try napa this weekend and see if i can get a match on the bearings. pressed them out and the part numbers are not ledgeable so gonna see what I can do.
thanks for the info....
blessings,
blessings,
