Turn Signal Issue
jor
Turn Signal Issue
Post by jor »
My turn signals aren't working. All lights work including brake and 4-ways. The symptom is: When I depress the brake pedal with the turn signal lever in the left position, that tail light goes out; same with the other side. Does this sound like the turn signal mechanism? Or what? Thanks.
jor
Thunderfoot
re: Turn Signal Issue
Post by Thunderfoot »
The light going out is normal from the way the turn signal switch in the column works.
Sounds like either the fuse for it blew or your "Flasher" died or came unhooked...
I would check the fuse first, same fuse is for the windshield washer and the back up lights so if they aren't working then it is the fuse.
jor
Post by jor »
Fuses are good; backup lights work Flashers are good. I switched flashers (4-way to blinker) to be certain. Not sure I understand what you mean by the light going out being normal. Thanks.
jor
Thunderfoot
The way the turn signal switch (TSS) works it disconnects the brake light connection inside it to the light you are using for the turn signal and connects it to the flasher. The flasher supplies the power to that light that has been connected now in the TSS.
So, from what you have checked out either the wire from the Flasher to the TSS has come unconnect at the connector on the column, or broke somewhere... maybe in the switch which you may be able to fix it.
Not sure what year your truck is but check the Blue wire with a test light on the wires to the TSS on the column connector with the signal on.
Joe Kriston
Re: Turn Signal Issue
Post by Joe Kriston »
jor wrote:My turn signals aren't working. All lights work including brake and 4-ways. The symptom is: When I depress the brake pedal with the turn signal lever in the left position, that tail light goes out; same with the other side.
jor
Hey, John...Long time no talk...Maybe you should try cheering up your brake pedal instead of always depressing it :) ...I wonder if the problem is in the switch at the brake pedal?...Mine is going bad, and I had to duct tape a spacer between the pedal and the switch so the brake lights didn't stay on when parked...And I noticed when I left my left turn signal on, only the right brake light would stay on and vise-versa...
Thunderfoot
Jor, Here is the older (on top) and new (below) style TTS connectors on the column. #44 is the Blue wire that comes from the Flasher.
Click and expand to see.
bad bulb or bad ground
basketcase0302
Post by basketcase0302 »
jor,
My vote is on the switch being bad.
Seems like one of my trucks had these symptons before, and it was the switch.
Basketcase
jor
Post by jor »
Well, thanks to all.
Either the wire from the Flasher to the TSS has come unconnect at the connector on the column, or broke somewhere... maybe in the switch
I don't see any broken or disconnected wires but I'll keep looking.
cheering up your brake pedal instead of always depressing it Smile ...I wonder if the problem is in the switch at the brake pedal?...
Pretty cute, Joe. Is a grimace kinda like a smile? The brake light switch is good.
I guess you are referring to the turn signal switch itself. That's what I'm thinking too but more checking first.
Thunder, thanks for the schematic. The one I have is the wrong year and shows different colors (haven't checked yours - this truck is a 68, btw).
I'll post when I get this thing figured out.
jor
montana_hiboy
Re: re: Turn Signal Issue
Post by montana_hiboy »
basketcase0302 wrote:jor,
Basketcase
I had very similar symptoms 1 year ago on my truck, turned out to be turn signal switch.
Jim
'75 Ford Highboy 390 4spd
SteveC
Post by SteveC »
yeah mine is having the same issue right now i cant figure it out replaced both flashers and the fuse was blowen before but i replaced it and still doesnt work even thought all other lights do.
Haven't checked the turn signal switch yet but seeing as how i am only up to dads once a week its hard to get to work opn it all the time.
wildcard
Post by wildcard »
Seems like I had that prob once in a 67 and it was the ground. But that was like 6 or 7 yrs ago. I remember running a ground all the way from the batt. to the light for some reason.
