24f or 27f
ezernut9mm
24f or 27f
Post by ezernut9mm »
which one was the original size for our trucks?
Thunderfoot
re: 24f or 27f
Post by Thunderfoot »
I seen this before and it was 24F... parts online that I looked at showed this also...
ezernut9mm
ok. i just wanted to be sure because when i did a search the people replied with both groups for the original.
i was thinking 24f too, but 27f was mentioned a few times.
My427stang
Post by My427stang »
Then 24F doesnt fill the battery tray, but it is the standard Ford size
Mopar used the 27F, it fills the battery tray.
If buying a battery for a non-resto, I would go 27F, for the oly reason that it it looks better to me. I doubt there is a significant difference internally
71 F-100 SB 4x4, 461 FE, Edelbrock Pro-flo 4, 4 speed, 4 inch softride lift, all poly bushings, integral PS, most mods installed since the 80's
70 Mustang Sportsroof 489 FE, EFI, TKO-600 5 speed, 4.11s
Engine building by-appointment only--30+ years, specializing in strong street pump gas FEs
ezernut9mm
i was thinking about buying a flat top 24f and using one of these:
they also make a cover for the 27f.
ToughOldFord
re: 24f or 27f
Post by ToughOldFord »
65 is a good one too, it fills the battery tray and you can get them with some serious CCA's as that's the size the diesels used. I replace the batteries in my diesels before they get old, IDI's love fresh batteries. I keep the old ones for my gas burners since they're still good.
