Gauge cluster questions
nadams
Post by nadams »
If you have a truck with just the idiot lights and you swap the gauge cluster out for one with all the gauges will the gauges work, or is there something different about idiot light wiring?
Hi, I'm Nathan and I approved this message.
1968 F250 LWB 360 (now 390) 4 sp High boy mine
1999 Expedition Eddie Bauer Edition 5.4 liter girlfriend and daughters
Joshpow
re: Gauge cluster questions
Post by Joshpow »
You have to change wiring. The charge gauge has to have a shunt while the idiot light doesn't. I am unsure about the oil pressure gauge. It may only require a sending unit change.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Right. If you decide to swap to a full-instrumentation panel, you'll need the underdash harness and the underhood charging harness. Not only does the full-instrumentation harness have the shunt, but the voltage regulator is also wired slightly differently. Read the following thread for more shunt info:
http://fordification.com/forum/viewtopic.php?t=2094
The oil pressure gauge would simply need the correct sending unit on the engine.
