horn doesnt work.
- 1971ford
horn doesnt work.
the horn doesnt work in my boss's 1970 f250.
i put in a new spring contact piece.
all wiring seems to be there.
all fuses are good (if that has anything to do with it anyways)
there is only one horn (should there be two?)
its NOT the horn relay, i bough a new one, installed it, didnt fix the problem and i took it back.
i believe the horn is getting no power. i could be wrong.
what should i check?
-Ryan
- SteveC
re: horn doesnt work.
well the best way to is just to take the wire off that runs to it and take a spare piece of wire and touch it to wire the regular wire hooks up and the positive side of the battery if it still has a good ground through the mounts to the radiator support it will honk if not adjust the screw if not try hooking a knowen working horn up to factory wiring and make sure it is ground and see if your horn works
Hope this is clear enough to understand it makes sense to me ....but a lot of things do that dont to others
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- SteveC
no problem best thing to try first is directly wiring the horn. Then try a different working horn. Just becarefull when testing the horn..i jump almost every time and usally wack my head on the hood latch
1967 f-100 4x4
1967 f-100 4x4
Run a jumper from the battery positive to the horn power connection. If you aren't deafened the horn is dead or the ground is bad. Clean the ground, which is the horn mounting bolt and try again. No beep=dead horn.
If it does beep then find the horn relay, passenger side under hood on or above inner fender. It will have 2 yellow wires and one blue/yellow striped wire running to it.
Remove the connector and jump the 2 yellow wires together, if the horn blows it isn't a fuse or the power wire circuit. If it doesn't blow check the fuse or if the truck is so equipped there could be a fusible link instead on the starter relay, large terminal where battery positive connects.
Reinstall connector and ground the blue/yellow striped wire if the horn works now the problem is in the ground circuit from the horn button.
Remove horn button ground out horn contact stud. If horn blows the contact isnt touching the horn button contact brass ring or the horn switch is dead or there is an accumulation of dirt.
If horn doesn't work check the rag joint grounding wire.
This should get you started
