removal of coat hooks inside cab.
1971ford
Post by 1971ford »
how do you get that black hook off of the interior wall of the cab? its right next to the 3-point-seat belt grommet.
-Ryan
TheEskimo
Post by TheEskimo »
If I remember right the black rubber peice slips off to reveal a plastic peice with a screw in it. But you may want to wait until someone comes in here that can say for certain this is how they work.
-Jason
1973 F100 Custom 390ci
1985 Thinderbird 302ci (DD)
AlleyCat
Post by AlleyCat »
TheEskimo wrote:If I remember right the black rubber peice slips off to reveal a plastic peice with a screw in it. But you may want to wait until someone comes in here that can say for certain this is how they work.
Your memory is correct. :)
Clay
BiggDogg
Post by BiggDogg »
Yes... I believe you can slowly slide in an upwards direction, and it should just pop right off eventually. The plastic piece it sits on tends to be a little on the fragile side (at least in my truck) so be gentle when sliding the black rubber piece off...
1970 F250 Camper Special
1971ford
Post by 1971ford »
hmmmmmm i tried slowly sliding upwards but it didnt want to budge :(
i must need a bigger hammer :lol:
-Ryan
i have tried to get those off. and i havent ever been able to do it. so they went to the junk with the rest of the cab.
1971ford
Post by 1971ford »
how easy are they to put in then? maybe i can brake this one off for truck painting, and then install a new one?
-Ryan
i couldn't even break one off.
1971ford
Post by 1971ford »
then you need a bigger hammer lol
-Ryan
