Heater Controls/ Light Switch
71Ford100
Post by 71Ford100 »
How do you remove these two items without breaking them?
Lance Peters
'72 250 4x4 project,''71 F-100 daily driver,69 F-250 4x4 Crew, '68 F-100, '68 F-250 crew under restoration, '52 Dodge 1/2 ton overload, gazillion tractors and combines
FORDification
Site & Forum Admin
Site & Forum Admin
re: Heater Controls/ Light Switch
Post by FORDification »
The heater controls are held on with two nuts, accessible from under the dash.
To remove the light switch, push the little button up on top of the switch itself (behind the dash) and pull out on the knob. This will remove the knob and stem. Then just just use a large flat-tip screwdriver to unscrew the bezel retaining nut, remove the bezel, and remove the switch from behind the dash.
MadMaxetc
Post by MadMaxetc »
Hey Keith, do you have a picture of everything??? :D
Dan
FORD Girl
Photobucket Pictures
67mann
Re: re: Heater Controls/ Light Switch
Post by 67mann »
FORDification wrote:The heater controls are held on with two nuts, accessible from under the dash.
:eek: Learn somthin new everyday---only problem is,I destroyed my light switch 3 days ago :doh: :lol:
well i have forgotten what size the nuts are on the heater controls. does anyone remember? i tired a few sockets on it the other night but they were the wrong size or they were going on right.
71Ford100
Post by 71Ford100 »
Thanks Keith
Lance Peters
i found out earlier those nuts are the same size as the door handle nuts. they are 11/32.
F100builder
Post by F100builder »
How about removing the wiper switch? :D
Patrick
there is a aleen head screw in the collar of the knob that has to be loosened to take it off. then you are suppose to use the little two pegged tool to unscrew the wiper keeper with. or you can use whatever tool you can get in there to unscrew the keepr with. thats it it pulls out from the back once that is all removed.
F100builder
I see the little thing now! Thanks!
Patrick
