which is very scary at night, but would it be the switch or the harnesses. i missed out on 390nut's harnesses but i will buy one when he gets time to make em again in the future.
but they were going off and on last night on the way home and i dont wanna get pulled over or worse hit something, my marker and taillights remained lit. just the HL's were shutting off and on.
is this the same problem you guys were having when you discussed blinky headlights?
headlights turn off and on (blinky syndrome)
- kilog55
- 19674x4
check the contacts in the back of the switch, that may be part of your problem also.
My Photo Album
- seattle67
re: headlights turn off and on (blinky syndrome)
Check at the headlight dimmer switch as well. That connection is pretty notorious for getting loose.
Dan
- 390Nut
90% chance it's the headlight switch itself, 10% chance it's connections at the headlight or dimmer switches.
edit: 9% chance it's at the headlight or dimmer switches, and 1% chance it's one of the terminals at the headlights shorting out (the terminals on the back of the headlamps can break loose)
Paul
`69 F100 390 4spd driver
- kaptnkaos
nuff said
KaptnKA S
- kilog55
yeah ill check both the HL switch and the dimmer
- ToughOldFord
Maybe you have the Highway Patrol edition of the bumpside!
Is it a uniformed on/off, like off for an equal amount of time each time? If so, you have a short to ground drawing too much current, headlight circuits use a self reseting breaker instead of a fuse for this exact situation. If a fuse blew it would be lights out. A breaker will cycle for safety. So look for frayed or rubbed through wires and you'll find your problem.
James
James
'05 Mustang GT
'72 crew 4x4
'07 KTM 450 xcw
2006 F350 CC Diesel 4x4 Lariat
'72 crew 4x4
'07 KTM 450 xcw
- kilog55
well i replaced the headlight switch with a used one off ebay and so far everything is okay but thats only a 2 mile trip ill have to bomb around and see if it fixed it or not
