Under the seat amps and subs?
kaptnkaos
re: Under the seat amps and subs?
Post by kaptnkaos »
The best way would be to make some shallow boxes to put yer subs in you dont have much clearance so to get the enought air space for the speakers, you need to make the sides wider...
you can put the air baffles on the side
There should be enough clearance to mount the amp(s) on the hump.
I took the tank outta the cab and am going to build a box that will use the tank mount to hang the speaker box on...
KaptnKA 8) S
kaptnkaos
Post by kaptnkaos »
hey CS...
Mine came with duel tanks, so all I had to do was remove the tank.
I crammed the filler tube up with rags so no idiot wold try to pump gas into it.
I have a tank to put on the other side under the bed, but haven't gotten to that project yet.
Yeah If you build the box for beind the seat you can baffle it on the bottom.
I haven't built my box yet.. But can see it in my head...
I just got the truck running again after sitting 5-6 years so I've had other priorities.
I found a decent cassette player that has a 1/8 inch stereo input.
With that, I can hook up an mp3 player and not have to mess with a cd player and can use the stock radio bezel without modification.
KaptnKA 8) S
