70 F100 Wiring Problems
I'm trying to get my truck ready for inspection but there are a few problems one the passenger marker light dosen't work but when it does it flashes with the turn signal and then the other side wouldn't work is it because i have the front one unhooked? any help i want to drive my truck so bad!
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- rjewkes
sounds like the marker got wired to th turns. should be connected in with the running lights.
curios where in mo?
and that pic needs shrunk to 80x80. if you need pix resizer i think theres a link on the main page.
curios where in mo?
fuelly.com
fuelly.com
- Underdog97
it sounds more to me like you have a short in the rear tail light to tail light harness. the side marker lights arn't suppose to blink at all. By the looks of your photo iether you've primed the bed or replaced it with another one. the side marker lights plug into a yellow female plug on the rear harness next to where the tail lights plug in. These are short little harnesses and one side screws to right behind the taillight on the bed. Good grounds are really important for the side marker lights. I would also check your rear harness where the main harness running from the front firewall plugs into it, as a lot of them have been cut up or spliced into for trailer lights. I'm not a fan of splice connectors as they break the insulation on the wires turning them brittle after a period of time which is one of the main causes for tail light problems, the other is grounding issues. Ford grounded the lights by the screws that fasten the taillight buckets and the #6 screws that the side marker light harness is screwed down with. the front turn signals have seperate wires running from the T/S switch so that shouldn't effect the rear lights or markers.
I Live In Springfield,But My trucks In Forsyth.rjewkes wrote:sounds like the marker got wired to th turns. should be connected in with the running lights.
curios where in mo?
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- rjewkes
cool, I'm over in joplin.
make the big S every once in a while.
did you get the wiring dfigured out yet?
I know under the truck the running lights are the brown wire(s).
these are where the wires for the side markers conect to eventualy. not sure of the color inside thhe area of the lights.
fuelly.com
fuelly.com
No i haven't messed with it yet because my trucks not at my house.Right now i'm working on finding another transmission to put in it,but once that's done im driving it for a while.rjewkes wrote:cool, I'm over in joplin.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
