Dash Speaker
Supermike
Dash Speaker
Post by Supermike »
Just wondering if anyone has replaced their under-dash speaker with one of the repros, if so where they got it, and if they are happy with it?
Right now I have a "box" type speaker mounted to the dash on the passenger side. I'd like to get rid of it as it's crackly and replace it with an under-dash speaker like the truck came with. I know NPD, LMC, and others sell dual-cone speakers. Anyone ever tried one of these?
Also, my stereo doesn't have RCA jacks, so can you use regular 'ol speaker wire?
Thanks!
Current owner of a 2022 Ford Bronco Wildtrak
mrtleavitt
re: Dash Speaker
Post by mrtleavitt »
I replaced my under-dash speacker with one from LMC. It was the dual speaker. I never had a speaker there before but it makes a heck of a difference. Not a single complaint about it!
Supermike
Post by Supermike »
Great to hear! Was it easy to do? Were you able to use standard speaker wire?
mrtleavitt
re: Dash Speaker
It was very easy. I have an after-market cd player in the truck so I used normal speaker wire. It was a direct replacement!
sideoilerfe
Re: re: Dash Speaker
Post by sideoilerfe »
mrtleavitt wrote:I replaced my under-dash speacker with one from LMC. It was the dual speaker. I never had a speaker there before but it makes a heck of a difference. Not a single complaint about it!
Which one did you use? The dual cone or the 2 speaker version? How did you mound it??? The factory speaker had a bracket in which the magnet of the speaker went into the bracket for mounting. I would like the dual cone speaker for mine but I need to know if both channels will be heard. Let me know!
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
Supermike
Post by Supermike »
I was wondering which one, as well... the dual coil one appears to be the best choice. It supports up to 130w, compared to only 30w for the dual speaker one.
The dual-coil one looks just like the original to me... so maybe it'll fit into the factory bracket?
mrtleavitt
re: Dash Speaker
Yup, that's the one I used. Worked just fine.
FRANKdaTANK
Post by FRANKdaTANK »
Can anybody post a pic of this set-up? I bought my truck without a stereo and need ideas for putting something in.
Thanks,
Frank
1967 F100 Shortbed - 390 FE w/ C6 trans. -- SOLD
1995 Bronco - 6" lift w/ 35" BFGs
1998 SVT Contour #3582 (Daily Driver)
FRANKdaTANK
FRANKdaTANK
Sorry for the double post..... thought my comp was locking up....
