I built a custom dash insert for my '69
F100builder
Post by F100builder »
Hey everyone. I just built a dash insert and installed my new gauges yesterday. I used a factory instrument cluster bezel that a P.O. had already cut a hole in so I didn't feel bad about cutting the center out of it to attach the plate and accept the VDO Cockpit style gauges. 8) huh?
More detail in my project update: http://www.fordification.com/forum/view ... c&&start=0
Patrick
seattle67
re: I built a custom dash insert for my '69
Post by seattle67 »
Very cool!
Dan
BiggDogg
Post by BiggDogg »
Looks good I dig it!
1970 F250 Camper Special
Ranchero50
Post by Ranchero50 »
Looks pretty cool. What did you do for turn signals etc? I did a custom panel for a '88 T bird a couple years ago and used a step drill set for depth to punch some same sized contoured holes in the metal for the lights to shine through. Ended up just siliconing the original lamp fixtures to the back of the aluminum.
Jamie
fitzwell
Post by fitzwell »
I likey :thup:
but what the hell is all that wire hanging out under the dash????? :eek:
F100builder
I'm going to drill 3 more holes for the turn signal and high beam indicators. The light I end up picking will dictate the size of hole. I'll use two green and a blue (maybe LED's). Fiber optics are cool too but too high tech for the 'rat rod' look.
Patrick
kaptnkaos
Post by kaptnkaos »
Good job F100builder...
That really looks nice... I like that look alot.
KaptnKA 8) S
F100builder
Re: re: I built a custom dash insert for my '69
Thanks Kaptn!
fitzwell wrote:I likey :thup:
Oh, you don't like that? :lol: Relax. I'm in the middle of rewiring the whole truck. That's all of the dash wiring waiting to go in. :D Note the late model style blade type fuses and the fuse block mounted in the same location as the stock glass tubes.
Patrick
iamthewreckingcrew
Post by iamthewreckingcrew »
Instuments look cool. Man, that's a big mamma jamma shifter too.
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
F100builder
iamthewreckingcrew wrote:Instuments look cool. Man, that's a big mamma jamma shifter too.
Thanks and yeah, the shifter is looong. Just wait until I get a knob on it with a little more attitude! 8)
EDIT: like this one!
Patrick
Big D's 69
Post by Big D's 69 »
Looks good man. A little time and effort goes a long way in making a statement.
F100builder
Thanks!!! :D
Patrick
1971ford
Post by 1971ford »
thats SWEET :thup:
im doing the same exact thing but with "swirled aluminum" instead of diamond plate :thup:
-Ryan
rjewkes
Post by rjewkes »
cool stuff did you go ron francis or painless?
i'm thinking about grabbin' the block from a newer f150 or bronco and soldering the original wires to the back of the block where they belong.
fuelly.com
F100builder
It's an EZ Wiring kit. The fuse panel is almost exactly the same size as the original (mounted in the same place too) but it has the blade type fuses rather than the glass tubes. I have extra circuits for A/C, electric fan, electric fuel pump, power windows/locks, etc. but I doubt I will use most of the extras...at least for now.
Patrick
