Emerg brake switch?
6T7Merc
Emerg brake switch?
Post by 6T7Merc »
Can anyone show me a picture of the emergency brake switch which turns on the small circular 'brake' light in the dash?
Thanks.
seattle67
re: Emerg brake switch?
Post by seattle67 »
That light is actually actuated by a differential switch located in your brake distribution block (drum/drum) or your proportioning valve (disc/drum)
Dan
Wes
Post by Wes »
:yt:
And when it comes on is bad thing means you have lost 1/2 your brakes.
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them :)
l1k2gadd
Post by l1k2gadd »
When it comes on it means you have an UNBALANCED condition in your brake system. It could mean that you have developed a leak somewhere (in a line, hose, wheel cylinder), or your master cylinder is pushing more fluid to one side than the other (going bad) or you have improperly bled your brakes and there is more pressure in the front than the back (or vice-versa).
I've been driving around with my light on for a while now!! When I finally checked the bulb about 6 to 8 months ago I found the bulb was blown. I replaced the bulb, and what did I find? Exactly what I figured would blow the bulb. The light is on all the time. Big deal! My brakes work fine, so far, and one day I'll take the time to balance my brake system (probably when I put my 3L50 posi BumpSide rear-end in the truck).
Check your truck over real good for leaks If you don't find any I believe there is something on this site that tells you how to balance the brake system out by bleeding the system a bit to the front or the back.
I did this on a 1967 Mustang I had the same problem with many years ago and the light went out in the Mustang. It would come on a bit at times and then go back off.
1971ford
Post by 1971ford »
:yt: my dad and i went through the horror of the brake light being on and it wasnt fun for my dad fixing it. we found that the little piston inside the cylinder thingy in the proportioning valve was jammed stuck :)
-Ryan
ToughOldFord
Post by ToughOldFord »
You guys are forgetting there is another dash light for when the e-brake is on.
I'll see if I can get a pic of the switch tomorrow.
1971ford
Post by 1971ford »
an e-brake light?
why that would be handy for my dad :evil:
he seems to forget and wonder why my truck cant get out the driveway lol
-Ryan
ToughOldFord
Here are those pics, first one is with the brake engaged, second one disengaged:
SteveC
Post by SteveC »
ive never seen one of those??? those on the 67 -72 trucks???? and where was the light located??
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
ToughOldFord
It's on my '69, I don't know if it was part of an option package or related to the year. I'll post a pic of the light in a minute.
1971ford
Post by 1971ford »
yeah a pic of the light would be quite dandy :D
ive never seen one of those before :eek: !
my 69 and 71 dont have them
im definately installing one lol
do you know where i can get one :?
-Ryan
ToughOldFord
It's the red one on the right, I don't have a lens for my system pressure light:
1971ford
Post by 1971ford »
now that is weird :? i think ill install a light in a cluster that i have plans for making.
clean them wires up!! lol
-Ryan
ToughOldFord
'K, how's that? :evil:
1971ford
Post by 1971ford »
good job :thup:
cant even see any wires any more !
EDIT: wait how'd you do that without it saying you edited the pic :?
-Ryan
