Door panels....take me to school.
fitzwell
Post by fitzwell »
Got to looking at what i have available for the'68 yesterday...nothing good. I want to keep the existing door handles on the inside, the window cranks are no big deal, i just need to know ......
what will interchange from 68 up, and is there a simple, all steel panel that was ever used?
i have a plan............ :wink:
Ranchero50
Post by Ranchero50 »
From what I've seen there is a difference between '69 and '71 with regards to the holes on the door itself. The '69 had the metal trim ring and holes for it's clips and the '71 didn't. Beyond that I don't know.
Jamie
Joshpow
re: Door panels....take me to school.
Post by Joshpow »
I believe that any 68-72 panel will interchange. The ones with the metal trim will have extra holes compared to the ones without. This isn't year related though. It has to do with the packages such as Ranger, Ranger XLT, Custom, and Sport Custom. The plain panels for plain jane trucks is solid steel with molded ridges. Hope this gives you a good idea.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
427blackpearl
Post by 427blackpearl »
this is the panel that should be on all our trucks
mine is a ranger so it has the trim around the edge
i found a spare set of panels and painted them cause i didn't like the after market plastic ones
wt4speed#2
Post by wt4speed#2 »
Mine are steel .
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
wt's ride
thebucket
Joshpow
Post by Joshpow »
Keep in mind guys, some had the vinyl covered fiberboard. Mostly XLT Rangers though. Some even had woodgrain on those panels.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
fitzwell
Post by fitzwell »
427...that's basically the panel i'm looking for. Going to upholster over it, so the trim isn't necessary (at least for what i have planned
thanks guys :fr:
427blackpearl
that should be on all our trucks as far as i know from the factory
1971ford
Re: re: Door panels....take me to school.
Post by 1971ford »
427blackpearl wrote:that should be on all our trucks as far as i know from the factory
well some had a hard vinyl with woodgrain through the middle, and others had a vinyl like material with a vertical wood grain in the ranger xlts. they are quite a few different panels for these trucks from the factory.
-Ryan
dcbullet
Post by dcbullet »
Those vinyl panels are on top of the steel door panel.
69twotone
Post by 69twotone »
I have found differences based on the panel regarding the holes drilled in the door. My 69 metal panel with a vinyl covering and wood grain would not fit on the 71 doors currently on my truck that had the 71 vinyl panel.
However I believe that if the holes were drilled differently it would fit. THe panels are both the same size but the 71 is vinyl only with no metal behind it.
69 f100 Custom cab Two tone maroon and white
Looking for a steering wheel with the horn ring, maroon or any color. PM me
kaptnkaos
Post by kaptnkaos »
:yt:
My '68 CS came with metal ones with the metal chrome trim.
My '71 CS came with the fiberboard panels covered with black vinyl with plasitichome trim...
I'm pretty sure that that it depends on which trim package you have, and what was ordered by the dealer / original purchaser.
Based on observation it seems that...
The base model got plain metal panels w/o trim,
The custom cab got metal panels w/ metal chrome trim
The Ranger and Ranger XLT models got various styles of vinyl covered w/or w/o wood paneling.
I think the '70 and newer models had mostly the vinyl ones in the Custom Cab packages regardless of the model...
Again, let me state that this assumption is based on observation...
I've not been able to find any documentation on this subject...
KaptnKA 8) S
rjewkes
Post by rjewkes »
My sport custom had vinyl with plasti-chrome trim.
the ranger xlt i had had vynal with vertical woodgrain around the window crank arwea and plasti-chrome trim.
and the doors off of a 69f100 had the metal panel w/o any trim.
fuelly.com
427blackpearl
weather it had vinyl or plastic or wood depending on model, i believe it still had a steel panel under the vinyl or plastic and it should be body color.
i didnt like the after market plastic ones from n.p.d. so i found a set of the metal ones and painted them the color of the plastic ones :2cents:
rjewkes
Post by rjewkes »
both of my 72's and more than likely my 70 had just the door behind the peannel no metal besideds the door. shell perhaps they changed it in 70?
fuelly.com
