'68 F100 Ranger Column shift knob question.
- 03rangerxlt
Does the shift knob on the column shifter just press fit onto the shifter, or is it supposed to thread on?
-John
1968 and 2003 Ford Ranger
"Honey, how 'bout I lock you up on charges of aggrevated dumb slut with no future?"
-Det. Ray Carling "Life on Mars"
"Criminals thrive on the indulgence of society's understanding."
- ezernut9mm
are you talking about the shift lever and the collar? if so you have to pull the steering wheel and then i believe you pull off the turn signal switch if you can get enough slack out of the wires, if not you have to cut the wires at the bottom of the column and then fish them back through after your done. its pretty self explanatory once you get the steering wheel/hub off. i learned this the hard way because my shift collar was broken when i bought my truck. oh by the way i have a 67 f-250 so it may be different depending on year and models and whatnot.1971ford wrote:yeah, those things are on there solid. good luck getting it off in one peice
i got a question...
how do you remove the shifter as a whole?
hope that helps
-miles
- 03rangerxlt
Aight. My ass became a drunk ass making a special shifter column knob for my '68 using a shift knob ordered from LMC and a .50BMG round. Hopefully will beable to get a pic up soon-ish.
-John
