Homemade Steering Column
- gramsay
I was looking at my steering column the other day and after deciding that I would like to replace it with something a lot nicer that wasn't riddled with adapter plates and huge gaps. I went to my good old LMC truck catalogue to price out a new chrome one and my jaw dropped at the price. I then decided that I was going to take on the ambitious project to build my own from scratch at work (I work at a machine shop by the way). I was wondering if anyone had any thoughts or suggestions for my little project. I'm thinking about making it out of aluminum or if my bank agrees, stainless steel.
- 71PA_Highboy
re: Homemade Steering Column
I would go find yourself an econoline Tilt column and use it as your base. That way you can have all the right pieces and parts for a tilt column and not have to reinvent the wheel - so to speak.
You will have to make a longer shaft and lower housing, but the head should fit just fine.
HTH,
eric
HTH,
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- carcrafter22
How funny, I was just talking with Marz about this yesterday. LOL. I agree with 71PA. I have thought of taking my 78 F150 tilt column and auto shift and then stripping the skin off of it so I could make my own out of fiberglass and in the process take the shifter off of the column.
I think you would be miles ahead if you just tool an already working column and made your own custom "skin" for it to make it your own style.
67 F100 sc/sb 07 Crown Vic IFS, 94 Lincoln Mark 8 IRS, isuzu 3.9L diesel w/ HY35 & HX 52 compound turbos and 370cc custom injection pump,T56 6spd trans, 18" 07 dodge magnumm wheels, old air products A/C (for a 66 mustang LOL). 32 mpg's so far, around town
- cathynkeith
hey its only here is the IDIDIT installed.
Cheaper to buy from IDIDIT then LMC.
Save $100.00
Save $100.00
http://s115.photobucket.com/albums/n292 ... type=local
Life is good...... when nothing is wrong that money can't fix.
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
1969 f100 flareside
- gramsay
I definitely like the idea of using a tilt steering column as my base. It should save me a bunch of time and fabrication. I do however want to upgrade most of the mechanical mechanisms inside the column to make it a lot stronger.
Very nice column by the way, but I like the satisfaction of making something myself.
