What are thease plugs for ???
FordTruck
Post by FordTruck »
I found thease two plugs inside the dash and I don't know what they're for I swaped cabs from a 70 to 70 and this is one of a few wiring things I can't figure out. Also my tail lights are staying on 24/7 no matter what I do they wouldn't go off so I've been unplugging the plug but the second I re plug it they come on so colud thease plugs have someting to do with that :?
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
BobbyFord
Re: What are thease plugs for ???
Post by BobbyFord »
Turn sig and hazard flasher.
Thunderfoot
Post by Thunderfoot »
:yt: but they won’t have anything to do with your tail lights staying on... They should have flashers plugged into them...
Is it the tail lights or the brake lights that are on? If brake lights check the brake light switch and make sure it is not staying on...
rjewkes
Post by rjewkes »
if it is the tails is your light switch pull knob in the switch or removed? if its out then the switch is in the on position.
fuelly.com
