Ebay tach??????
mljjones67
Ebay tach??????
Post by mljjones67 »
Any one know if this tach is out of a f-600 gauge cluster? And can i get it to work with my cummins conversion?? it says its electric? :? :?
http://cgi.ebay.com/ebaymotors/Ford-Tru ... 240%3A1318
drytoast
Re: Ebay tach??????
Post by drytoast »
Seeing the plug it looks to me to be newer than 67.Todd
Life is hard; its harder if your STUPID. John Wayne
1972 Ford F-100 Explorer 302 C4 automatic
2005 Chrysler T&C Limited
1996 Honda Accord LX 238,000 miles and counting
papabug71
Re: Ebay tach??????
Post by papabug71 »
The later f-600's had electrical tachs. Im not sure if it will work on your cummins or not???.. I would think it would. Both my Dodge diesels had electric tachs.
I dont think this one is from a f-600 tho, maybe a ford school bus??
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
Re: Ebay tach??????
it looks right. and by the way he talks it sounds like it will fit in the f600 panel. i cant help you with hooking it up though. don't the electric ones run off of the coil?
mljjones67
Re: Ebay tach??????
Well I found another and was wondering if this one will work and fit in the gauge cluster? I need to email him for measurements.
http://cgi.ebay.com/ebaymotors/65-66-67 ... 240%3A1318
Hawkrod
Re: Ebay tach??????
Post by Hawkrod »
That is a correct diesel tach, that is why it only goes to 3K. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
mljjones67
Re: Ebay tach??????
Thanks Hawk. How would I run this tach off my Cummins?
Hawkrod
Re: Ebay tach??????
Post by Hawkrod »
They are cable driven, I am not sure where it would come off of on your engine but some older engines used a tach drive off of the generator. Going along those lined you could probably make something that is driven by the fan belt. You need it to turn 1 revolution for each revolution of the engine. Should not be too hard to make something like that up. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
