69 f600 wiring diagram
Does anyone know where i can find a wiring diagram for my 69 f600? I can't get my brake lights to work and think they are wired wrong. All the wiring diagrams i have found only go up to an f350. Any help would be greatly appreciated.
- Thunderfoot
Re: 69 f600 wiring diagram
Does it have the Turn Signal Switch mounted in the steering column or is it and external mounted switch? If it is internal then the F250-350 wire diagrams should still work as Ford was pretty good at keeping wire colors the same through all models… Even for an external it should be close… might be able to help out with it…
Anyway, for diagrams you might check with this place and see if they have them. http://www.wiring-diagram.com/?gclid=CI ... agodbD3oYw other members may have some other places to look. I know Kaptnkaos has a Bus so he might have found wire diagrams for it.
Wiring-diagrams did show one for the f600, mine does have the switch in the column. It ended up being a bad connection in the fuse panel, sandpapered the fuse holders and now it's good to go! Thanks!
