What vehicles had the 3g?
saidyene
Post by saidyene »
What vehicles come with the 3g alternator? I have run across a few but just wanted to see what else I should keep an eye out for.
Thunderfoot
Re: What vehicles had the 3g?
Post by Thunderfoot »
Quite a few during the Mid to late 90's but some are different configuration that wont work. Check out the 3G thread at the top of this forum http://www.fordification.com/forum/view ... =8&t=13062 the last info I found for the ones the right size to fit I listed the info at the end http://www.fordification.com/forum/view ... 30#p337434 There is also a lot of info on the internet on this swap as well, just do a search for "3G alternator conversion". :wink:
fitzwell
Post by fitzwell »
98 mustang V6. fits our trucks with little or no modification. Mounting legs are in the correct position. You might have to take .060-.090 off of the back of the drive pulley for a perfect alignment, depending on your brackets, alignment of the stars, etc....
saidyene
Post by saidyene »
96-00 FORD All Models V6-232 3.8L
94-95 FORD MUSTANG V6-232 3.8L
94-95 FORD THUNDERBIRD V6-232 3.8L
94-94 FORD All Models V8-302 5.0L
95-95 FORD All Models V8-302 5.0L
96-97 MERCURY All Models V6-232 3.8L
94-95 MERCURY COUGAR V6-232 3.8L
This is the list from ford. I going to assume this is the complete list as its from the source. I do believe there are other 130+ amp alternators out there but they are not the 3g with this part number.
