Spare
- OldBlue67
re: Spare
my CS came with one, mounted under the bed. I guess I just assumed that all of them did, could you not get a spare tire? ![Hmmm :hmm:](./images/smilies/icon_hm.gif)
~Liz
Old Blue Truck is Old and Blue
Ugly as sin but dont get in my way VA-ROOOOOOMMMMM!!
![Evil :evil:](./images/smilies/icon_evil.gif)
re: Spare
AFAIK all trucks came with a spare tire. With most trucks it would either have been mounted in the bed on a special bracket or under the bed behind the axle. However, considering the likelihood that a Camper Special might usually have a camper in it, the spare would have been mounted under the bed or even on a special bracket up front in front of the grille.
- Hawkrod
re: Spare
Not all trucks came with a spare. It is rare to not have one and I can't provide the specifics off of the top of my head but I seem to remember a blurb in an order manual about deleting the spare for a cost credit. I think it was aimed at fleet sales. I do know that my 76 Crew Cab was ordered without one because the paper work shows it as a delete option. But mine was a runway truck on an Air Force Base and was one of many at the base and so they likely only needed a couple of spares to service large number of trucks. Why pay for something you don't need? I could see a similar situation in construction where a company may run a fleet on a site and a couple of spares would service many trucks. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
re: Spare
When I ordered my truck new in 76 the spare wheel & tire were standard on the F-100's and F-150's. However they were optional on the F-250's and F-350's. If you were ordering a 250 or 350 you needed to check the box for a spare.
- shrektruck
re: Spare
I saw a 72 (i think) at the boneyard last week that had a removable cutout in the passenger side of the bed where the spare was mounted. I gotta start bringing the digital with me to the boneyard. I'll bring it by today and try to get a pic.
- Hawkrod
re: Spare
That removeable panel makes what you saw a 73-79 F350 Fleetside. They had a longer wheel base than other trucks and most of them are what are called Super Camper Specials. Not all of these are SCS's but definitely the majority. I know keith needs the mounting hardware for the rear gas tank on one of these (they are special). Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
- shrektruck
re: Spare
You know what? It was a 73. I was pulling tailgate hardware and the cargo light. Got confused jumping around from bed to bed. I do remember thinking that would be cool and that I could put another tank in the spare tire space.
Kieth, do you still need parts off one of these?
re: Spare
Absolutely! I have the tank, but I need both mounting straps and the skidplate. I could also use the two rear crossmembers that the skidplate bolts to, but since they're probably riveted in, they'd be a major hassle to get out. If they just unbolt, then definitely grab those too. And if the exhaust heat shields are still there, I could use those as well.
Here are a couple pictures of the setup removed, courtesy of Hawkrod:
- shrektruck
re: Spare
Ok, didn't get to the boneyard on Thursday, work went on and on and it was dark when I left.
Got the digital today though and soon as I finish up here I'll run over.
I don't have a cold chisel in the toolbox (but I think I'll add one now) so rivets would be a problem but there's always tomorrow.
- shrektruck
re: Spare
Hi Kieth,
Finally got to crawl around the boneyard on Friday. (
Marie thinks I was working.
The gas tank setup was gone out of the 73 but I found a 76 with a setup that had a tank with the spare mounted under that. The owner seemed to think it was pretty special as he wanted $250 for the whole setup. I had to pass. It looked like so:
![Shhh :shh:](./images/smilies/icon_shhh.gif)
- shrektruck
re: Spare
If you want I'll be happy to go yank it. It looked real clean but I thought $250 was pretty steep for a tank.
The '73 F-350 fleetside was picked pretty bare but did have a 4bbl intake (390) and that cool spare mount (no cover though).
Here's a pic of that. Wonder if the bottom of the 76 bed can be married to the top of a 72 to give you that storage.
re: Spare
I appreciate the effort, that's not the one I'm looking for. That's actually just a standard truck tank. The one I need hardware for is the F350 Super Camper Special tank. The SCS trucks have an extended wheelbase (140") and the spare tire is mounted in a special compartment in the passenger-side bedside.
![Image](http://www.fordification.com/board/1973-F350SCS_01.jpg)
As you can see, the rear axle is extended back enough that there wouldn't be room for a spare tire behind the axle. Here's what their spare tire storage compartment looked like:
![Image](http://www.fordification.com/board/1973-F350SCS_02.jpg)
