ignition keys
warponyxlt
ignition keys
Post by warponyxlt »
does any one out there have the kind of key that one side is for the doors and the other is for the ignition meaning they work only one way up for the ignition and down for the doors that is the way my truck was untill i lost them in a snow bank in november last year any one know where to get a replacement :?
if its fixed break it again red white and ford blue the only up hill thats good is the one you are going down
Re: ignition keys
our trucks came as a two sided key that fit in all three locks. either way up or down. if you had soemthing like that then someone has changed the ignition switch at one time and didn't swap the key cylinder out to match the door locks. atleast thats what it sounds like to me. unless you have a key to fit either lock you will have to go to a lock smith and get the keys made for the locks you have or swap out for a matched set of keys.
warponyxlt
Re: ignition keys
there is two different sides on one key one for the ingnition one for the door locks
heartless
Re: ignition keys
Post by heartless »
i, personally, have never seen a FoMoCo key with two different cuts (one cut on each side) - both sides of the key are cut exactly the same on every Ford, Lincoln or Mercury key I have ever seen - and it made no difference which way the key was turned. Have had quite a few over the years...
If you had something of this nature then you have a "special" cut key and the only way you will get that key again (short of finding your lost key) is to have it made by a competant locksmith. Locksmith will need access to the ignition switch & the door lock...
Good luck
altho, in retrospect, I havent actually seen/held a newer key (last 10yrs or so...LOL)
Bullitt390
Re: ignition keys
Post by Bullitt390 »
New keys are still the same way... reversible
ok68crewcab
Re: ignition keys
Post by ok68crewcab »
fordman wrote:our trucks came as a two sided key that fit in all three locks. either way up or down. if you had soemthing like that then someone has changed the ignition switch at one time and didn't swap the key cylinder out to match the door locks. atleast thats what it sounds like to me. unless you have a key to fit either lock you will have to go to a lock smith and get the keys made for the locks you have or swap out for a matched set of keys.
Fordmans idea sounds most likely. I have also heard of people with two Ford vehicles putting one car on the top half of the key and one on the botom so with one key it would fit either vehicle if put in the ignition the right side up.
2 Blessed 2 Be Stressed
taylor351
Re: ignition keys
Post by taylor351 »
:yt:
Done it, works pretty well. Two trucks one key. Frustrates the heck out of people who are not used to it though. Fumble and grumble.
Keith
2004 Dodge Ram 1500 Quad cab 4.7 liter Daily Driver
1993 f150 351 4x4
1969 f100 Ranger daily driver wantabe
1972 classic c10
Proudly serving Christ since 2000
God bless our troops
A bitter rural American clinging to my guns and my religion.
towtruckerfour
Re: ignition keys
Post by towtruckerfour »
My dad and I did that on my two trucks a while back. Pretty neat idea
Troy
Re: ignition keys
i know what you were saying. its the same deal with putting two different trucks on one. key. kind of a pain but also kind of handy. and if you ever sell one of the trucks you better have another single key made just for the truck your selling.
sideoilerfe
Re: ignition keys
Post by sideoilerfe »
Get a new ignition lock then have a locksmith re-key the door lock cylinders to match. The door lock cylinders come out very easily.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
HillbillyDelux
Re: ignition keys
Post by HillbillyDelux »
when i bought my '69 it had 2 keys one for doors one for ignition cuz the po changed the switch or the door lock. so i had the keys cut onto one key.
i had an '86 f150 that actually had separate keys for door and ignition from the factory like a cheby
2000 Ford Ranger 4x4 "DD"
2003 Cobra
"If it ain't broke fix it til it is"
Re: ignition keys
i think it was 80-86 that ford had two keys for the doors and the ignition. in 87 i think they went back to one key only for everything.
thebannister8
Re: ignition keys
Post by thebannister8 »
heartless wrote:i, personally, have never seen a FoMoCo key with two different cuts (one cut on each side) - both sides of the key are cut exactly the same on every Ford, Lincoln or Mercury key I have ever seen - and it made no difference which way the key was turned. Have had quite a few over the years...
Good luck
my 67 mustang has one key for the door and the ignition...each side of the key has a different cut :hmm:
