Guages vs. Dummy lights
- Brokenarrow
My '68 has the "dummy lights" in the dash cluster. I tried to use a '69 cluster with guages but I couldn't get the blinkers to work I changed out the flasher, thinking it was bad but they still wouldn't work. Everything works fine with the original '68 cluster, and everything worked fine in the '69 when I parked it. Both harnesses have a C8 part number. Any ideas?
'68 SWB f100, 401ci FE/C6, '68 Mustang fastback (restoration in progress)
2013 F150 KingRanch (ecoboost), '48 8N tractor
"Be more concerned with your character than your reputation, because your character is what you really are, while your reputation is merely what others think you are."
— John Wooden
— John Wooden
Re: Guages vs. Dummy lights
Full-instrumentation clusters take a completely different underdash and underhood wiring harness, to accommodate the ammeter wiring. The positions of some of the wires in the connectors are slightly different as well, since additional wires have to go up through the same connector. I can't say for certain without looking at the wiring diagrams whether the turn signal wire pin positions were changed, but it's certainly possible.
http://www.fordification.com/wiring.htm
