Sloppy stick...
V Majestyk
Sloppy stick...
Post by V Majestyk »
Anyone find a painless (relatively ) fix for slopstick with the T18's. The pin hole in my housing is wallowed and cracked across the top and the slot in my stick pivot is worse off. Am I swapping in my 84 NP or can this be dealt with reasonablely? :pray: :cry: :help:
Don't need re-stored,can,t wear the d*mn thing out !
willowbilly3
Re: Sloppy stick...
Post by willowbilly3 »
Drill and grind for a bigger pin? If it is cracked you might need to find a better shift tower and lever. If the rest of the transmission is good then you can just take out the tunnel cover and swap out the whole top.
Alvin in AZ
Re: Sloppy stick...
Post by Alvin in AZ »
willowbilly3 wrote: Drill and grind for a bigger pin?
x2
What's your brazing (red hot soldering ;) and blacksmithing (hammering
it back into to shape while hot) skills like? I believe I'd take the lid off
and try that stuff first, then put on a "new" lid after I screwed it all up.
Hey, it's broken and only a crummy boat anchor now.
I put washers and spacers (and I don't know what all) on the bottom end
of my T18 gear shift lever to stiffen up the feel of it. Was hoping that
was all you needed. LOL :)
Alvin in AZ
ps- Holy smokes I can edit this sucker a half a day later? :)
http://www.novak-adapt.com/knowledge/np435.htm
Sazman
Re: Sloppy stick...
Post by Sazman »
I had the same problem on a T18 I inherited, except where the shift pin went had cracked out to the top of the tower and the whole chunk, a triangular piece about 1 1/2 in. long was gone. There was no way it would hold a pin anymore. The corresponding slot in the shifter was wallowed out pretty bad too from all the rough treatment this poor tranny went through. I took off the top cover and with a magnet,fished out two real beat up shift pins out of the bottom and a bunch of chips and shards off the teeth I guess. It dawned on me to just drill the opposite side of the tower for the pin, easier said than done because of the shape of the shouder with the threads to screw on the cap. But I finally got through it, although a little higher up on the tower than it should be. Then I just marked where I wanted the slot directly across the shifter from the wallowed out slot.I cut that with a die grinder. A little fine tuning, and it's working alright now. I probablly should have got someone to braze it for me, but I think it will work OK. BTW, as has been said here before, a 1/4 in. drill bit shank seems to be about perfect diameter for the pin. 5/8 in. length, I have a T-98 in a slick, and it is the same.
1965 F-100 300-6 working on it, wanted a first year Twin I-Beam 300, now I gots one
1971 F-100 Custom 302 C4
1962 F-100 Custom Cab 292 3 on the tree, restoring, probably gonna sell it I guess. Love the engine.
1972 Maverick 2 DR 250 I-6, C4, restoring.
1978 F-150 always wanted one of these too. 300, 3+1 OD trans, pretty well preserved, working on it
1985 F-350 460 crew cab, rough as a cob
All these are southern Arizona desert trucks, little to no rust, but the sun takes its toll,ha.
BigFoot
Re: Sloppy stick...
Post by BigFoot »
willowbilly3 wrote:If the rest of the transmission is good then you can just take out the tunnel cover and swap out the whole top.
This is the best news EVER!! Thanks for the tip.
Now, where to source a gasket for the top of the trans.
THANKS!!
