Flickering lights
Flickering lights
I'm having problems with flickering lights on my truck. At an idle all the lights, right down to the dash lights, "pulse" like a heartbeat. The higher the RPM's the faster the pulse and the less noticeable the effect becomes. The voltage regulator and alternator are brand new. I've got a heavy duty ground strap running from the engine to the frame but it doesn't make a difference. I'm sure it's a ground problem but I wanted to check with the experts to see if anyones encountered the same problems and hopefully get an idea of where to start to clear it up.
- heep70
Re: Flickering lights
I went to a one wire alt many years ago and that solved my problem. Lot of folks here I read to the 3G alt but I am not sure if they are tryng to resolve the same issue. I also heard that if you switch out the big regulator for the smaller solid state regulator that will stop the pulse also.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- Thunderfoot
I had this similar issue on mine and after my alternator quit working this flickering stopped (was supposedly a new alternator on the truck when I got it, and it looked it) I replaced the alternator with a good used one I had and it went away… I would suspect the new alternator is the problem… I’m guessing if you got a new Regulator it is the solid state one.
Thanks guys. I'll start there and hope it clears things up!
just puttin it out there but check out your dimmer switch wire plug in it does that also it will get you very very mad especially during night driving
if its fixed break it again red white and ford blue the only up hill thats good is the one you are going down
