70 mach 1- 3 point seat belts
wobblefoot
Post by wobblefoot »
Does anybody know if 70 Mach 1 Mustang 3 point seat belts will bolt right in a 71 F100? :hmm: Arnt seat belts seat belts :? ,I myself would think it wouldnt matter my :2cents:
I hope some one can answer this because I found some in good shape.that match my color. :pray:
69 ford f100 Longbed restored 360,auto
71 ford f100 302 3spd shortbed my daily driver
Re: 70 mach 1- 3 point seat belts
i think on belts like that length would be the main thing to think about. and those could be long enough or a little longer than a truck would need. so you may be able to use them.
Joshpow
Post by Joshpow »
I've tried new model ones that are too short. They might very well fit fine, but length would be the major concern.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
mike68merc
Post by mike68merc »
:evil: You could probably Ebay those Mach I belts to a Mustang Freak & pay for a cool pair of aftermarket 3 Point Belts like these:
http://www.fordification.com/forum/view ... seat+belts
(If the link doesn't work)...its in a thread called; I just installed 3 point seatbelts in my 67.
This is the Company he got 'em from:
http://seatbeltpros.com/
Good Luck.
71PA_Highboy
Post by 71PA_Highboy »
The 3 point belts will bolt up just fine.
That doesn't mean they will work well. The big issue as I see it is the center receiver. There is nothing to hold it in place (on the seat where you can clip in easily) if at all...
I agree, ebay the mach1 stuff (They are 70 Mustang ONLY), and get a pair of aftermarket seatbelts. The retractors will be more robust, you can get them with the reinforced receivers on stalks (so they 'Sit-Up' between the seats) and often are available in more color combos.
JMHO,
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
