Go faster maker happener mounter broke!
FreakysFords
Post by FreakysFords »
lol.
My throttle pedal to fw mount broke. I've messed with old Fords for many years and I don't think I've ever broken one. I've got 2 dent parts trucks a 76 and what I think is a 77. If it's the same part on the dents, I'll make a trip 2maro to yank parts.
Are they the same? I just don't recall! lol
Darrman
Re: Go faster maker happener mounter broke!
Post by Darrman »
No, I went through this ordeal already, bumps have a pedal screw and have a unique shape out side the firewall, dents have a pressed pin for the pedal and the outside shape is different.
However, the mount is the same, and as long as you keep the pedal with the rod and do alittl tweaking on your throttle linkage, you can make it work.
yes pretty much the dentside ones will work fine. the only difference is some of them have the pressed in pin fo rthe foot pedal and i think all of them have the peg as well as the hole in them fo rthe two types of linkages. i would check out what you have and see if they will work. i don't have any to get rid of right now.
two-bit
Post by two-bit »
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
I almost blew coffee out my nose when i read that title.
Two-bit
thebannister8
Post by thebannister8 »
:yt:
FreakysFords
lol had to get a chuckle or two.
I did make a run early this AM and yanked the one from the 76 dent. There was a minimal length difference, but since both were similarly equipped, I yanked the linkage as well (had to pull the ball off the carb link as well since it was a little smaller than my old one) and it worked fine. In fact the geometry is better now. Looking at my 73 dent, which had a 6, there was a major difference. My thinking is that it's about the differently equipped trucks making major differences.
I did however swap the actual pedal pads back. The dent's was all plastic and I wanted to keep my metal backed original.
The only real difference I found is that the dent pedal pad was pinned on rather than bolted like my bump so I'll be tapping the hole in the rod at work 2maro so I can go back with my original bolt rather than the tractor pin that I have in there right now.
OK, so if anyone wishes to know.
I looked over all the dents and bumps out there at the farm and the differences above were the only ones I saw. I didn't see a single dent throttle pedal assembly that wouldn't work on a similarly equipped bump.
Now for the good news. On the way back, my MC blew it's chance at remaining in my truck by blowing the shaft seal. Got a nice soupy mess in the floor pan and my parts trucks are the other way. lol I'd rather put new back anyway. Oh and guess what.... my 3 parts trucks, and a neighbor's 20 or so and not ONE single brake booster equipped truck. lol
