following is my list of things that need repaired on it.
cab mounts floors rocker corner curve bed seam resealed new door or a door repair in each of the outer two lower corners of the passenger door and a whole new front clip. as well as the enigne reinstalled.
since this truck isnt going to be a frame off and just a work truck. i'm not going to go hog wild on it. and repair everything with new parts. i will do my best though to be very professional about everything i do to this truck.
the first thing i have done is to take it to the car wash and steam clean off most of the dirt and grease. i still need to go back and finish the wash job. i ran out of quarters on that day. i also took an inventory of what body parts i could reuse from the front clip and reduced the pile of body parts to a more easliy haulable load for the scrap yard. i also have picked up a front clip from the junkyard that need some work to it. this truck also has bedliner material all over the whole body. the truck was orginally red. i am unsure if i am going to remove all of the bedliner material off of the body or not right now. these pics are before i done anything to the truck.
