EZ wiring kit install troubles
lifted72
Post by lifted72 »
Im installing the EZ wiring kit, and am having troubles trying to figure out how to incorporate the stock headlight, ignition, emergency flasher and windshield wiper switches. If anybody has installed this kit (its the one with 20 micro fuses) and can shine a little light on my situation that would be amazing. Thanks guys
POLISH EVERYTHING
Roadrunner351w
Re: EZ wiring kit install troubles
Post by Roadrunner351w »
When I did mine I used the original connectors just spliced into them and left a little bit of the original wire on the connectors so it would make trouble shooting a little easier. and the same with the connectors on the lights also. I also did the same with the dash gauge cluster and the wires to the steering column. Hope this helps.
Roadrunner351w
