Good evening!
Is this box a voltage regulator? And if so, do I need to keep this if I'm going to use a 3G alternator?
Thanks very much!
Robroy
Is this a voltage regulator (photo), and does 3G use it?
- robroy
- kaptnkaos
Re: Is this a voltage regulator (photo), and does 3G use it?
Yepper Robroy that's the regulator alrighty...
not sure about the 3g.. I think it might have and internal regulator
KaptnKA S
KaptnKA S
- robroy
Hey KaptnKA S thanks for replying!
If the 3G has an internal regulator that might simplify things a little bit (one less thing to keep track of).
Thanks again,
Robroy
Thanks again,
Robroy
- 71PA_Highboy
Yes, the 3G is internally regulated.
No, you do not need the piece in your hand if you are using the 3G. Just make sure you keep track of the wiring becasue you are going to want to connect the 3G to the greeen/red stripe wire....
hth,
eric
hth,
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- robroy
Hey Eric, thanks! That's great news. I'll make sure I keep an eye out for that special wire.
Thanks again,
Robroy
Thanks again,
Robroy
yes that is a electronic voltage regulator. it is a replacement for the factory adjustable type.
