Carpets on ebay?
- madbiker4
Carpets on ebay?
has anybody ever bought the carpets sold on ebay? how is the quality and fit? just wanted to check before buying one. http://cgi.ebay.com/ebaymotors/1948-200 ... enameZWDVW
1972 f100 ranger xlt, 300 cid I6, Clifford performance 6=8 intake manifold, Holley 600 cfm 4bbl carb, Heddman dual exhaust headers, dual flowmaster mufflers, duraspark II, power disk brakes.
Re: Carpets on ebay?
i can only tell you two things. the nylon loop is the correct look for our trucks. the cut loop is a crappier version. and will wear out faster. the second thing is that wehn ordering the carpet. transmission isnt the way to order. it is if you truck has the tall transmission hump or the low transmission hump. all of the early automatic. except c6 used the low hump. c6 and all of the manual transmissions except 3 spd on the column used tall humps. you may talk with this person about that before buying. the low hump is a 5 inch center hump and the tall hump is a 8 inch high hump.
