ignition wiring
hotrod ford
ignition wiring
Post by hotrod ford »
finally started to get a look over today on the 67. not to bad. the ignition though is crap. where the black plastic housinf meets the metal housing is briken to no repair. i do though still have a wire harness from a 70 to use. since the to years wire harness colors are different, i was wondering if anyone knew which color wires i would have to match up for the 67 ignition wire to the 70 ignition wires? thanks. :thup:
Re: ignition wiring
check out the wiring diagrams that should give the colors. http://www.fordification.com/wiring.htm
hotrod ford
Re: ignition wiring
i looked at those and it shows the 67 ignition but not the 71 ignition wiring. i don't want to cut the wires, i think it will be easier just to replace the ignition housing.
