72 F100 Bright lights problem
03svtsnakevert
Post by 03svtsnakevert »
Ok, here is the deal...when I am driving my truck at night, I can activate the bright lights and they will come on and stay on for some time and then after a little bit they will shut off...all dash lights stay on, etc etc...then they will come back on and shut back off for a minute...I can cycle back to low beams and they will work...dimmer is new...H/L switch is fairly new...headlights are new...cleaned the grounds at the bulbs...any thoughts?
Low beams will run always...they will never do this...even did it while sitting in my driveway...
seattle67
Re: 72 F100 Bright lights problem
Post by seattle67 »
There is a self resetting circuit breaker built into the headlight switch that will turn on and off like that. Either it is not working correctly (they get weak and trip too easy) or your high beams are pulling excessive amperage for some reason, such as newer, higher wattage bulbs.
Dan
get a new headlight switch.
03svtsnakevert
Will try that
fmartin_gila1
Post by fmartin_gila1 »
Add a relay setup to eliminate the load on the headlight switch. lots of info on how to do it.
Fred
03svtsnakevert
I put a new switch in it...so far so good...Thanks!
