Wire Harness
Jimbo
Wire Harness
Post by Jimbo »
Has anyone put in an aftermarket wire harness? If so do the come with the conections on the ends to just hook up and go? Thank you for any info.
Jimbo
Re: Wire Harness
no i think it is just a pile of wires and you have to put your old plugs on the harness. thats alot of money to have to reuse your old plugs.
mrsnicks
Re: Wire Harness
Post by mrsnicks »
Check out RonFrancis and Painless products. They sell new fuse blocks and new wiring harnesses + fuse blocks. I know they have some that are application specific and some that are year/make/model specific. Not sure if there is a specific one for our trucks or not. I see the 12/18 circuit fuse blocks from painless on evilbay from time-to-time.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
rjewkes
Re: Wire Harness
Post by rjewkes »
I have been wanting to snag an eighties non efi systems blade fuse block i think they are 8-12 fuses/circuits and if done right would fit in the stock location and hook straight up to the old harness unless you wated to run new wire following the original wires before removing them.
fuelly.com
