REDOING FLOORS NEED HELP
57fordf100
Post by 57fordf100 »
ok guys i riped all the old carpet out of the truck i started cleaning up the floors with a wire brush thats as far as iv got imma paint the floors with bed liner i heard it helps from making the floors worse plus helps with sound and i read somewhere that a guy used heater insulation for the heat would that work fine or would it cause problems down the road what do you guys think i dont have to much money to spend so yeah what would you guys recommend
FORD IS LIFE OIL N GAS IS MY BLOOD
towtruckerfour
Re: REDOING FLOORS NEED HELP
Post by towtruckerfour »
I have bedliner on mine and it looks good. It does quiet the noise a bit too. And the metal is protected now from moisture with the bedliner material.
Troy
57fordf100
Wat about the water heater insulation cn i use that for the heat
flyboy71
Post by flyboy71 »
U mean using insulation on the floor or firewall? On the firewall it should work pretty good compared to the original. Not sure about the floor.
-Jeff
