Anchors for seatbelts
3 Speed
Post by 3 Speed »
My '67 has four anchors for belts on the floor (plus the two pre-drilled holes above for the shoulder belts).
Are those four anchors intended to serve three seating positions, or am I required to add two more anchors for the middle seating position, using the non-threaded holes already in the floor, currently filled with rubber gaskets?
67 F101 Custom Cab longbed, 352 V8, 3 speed manual
Re: Anchors for seatbelts
the original three passenger seat belts botled into the and with both the drivers and passengers bolt holes. so the center two bolts had two belts each attached to them. the holes int he cab wall are for thre point seat belts.
3 Speed
Post by 3 Speed »
Thanks, Fordman. Now to find those 3/8 bolts with shoulders for the top belts!
you can get those botls out of any car or truck. for the top holes
3 Speed
Post by 3 Speed »
Meant to tell you that I found the bolts at an industrial supply house. Worked great.
were your top holes threaded?
3 Speed
Post by 3 Speed »
Yes they were. I cut out the original rubber plugs and put the shoulder bolts in.
cool i guess some were and some werent.
