Metra Kit
- 71PA_Highboy
Re: Metra Kit
Yes, It will wobble without a back brace.
Depending on what you use for a back brace, it may still wobble, but the amount will be significantly less.
If you install withoug a back brace you will regret it after the first really badly ruttted or pot-holed road as they wobble will just increase with the additional wear
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
Re: Metra Kit
Both mine are mounted and do not have a back brace. I haven't had any problems yet but a back brace would not be a bad idea. Maybe make a bracket that will go from the radio to the center dashpad bolt. That is what I will probably do.
Troy
Re: Metra Kit
Yes I dont have a dash pad, but I will get one. Itcame with a back brace, so Im gona put it on.
Re: Metra Kit
My volvo kit came with the part to connect it to the factory back brace, it worked perfect. Yours should also have this part?
- flyboy2610
Re: Metra Kit
I just used a piece of metal plumbers tape (the metal strap with lots of holes) and fastened mine to the stock speaker mounting bolt.
Re: Metra Kit
Ha, mine came with its own modifed plumbers tape. but Yea ill stick stick a bolt through the dash for now, untill i get a pad.
