Headliner/Door Panel Questions
Jay's67F100
Post by Jay's67F100 »
I'm starting to fix up the interior of my 67 F100. I pulled down the headliner to paint it and the trim, it's missing one trim screw and what ever holds in the headliner to the roof from the center. I've looked in 3 different parts catalogs (NPD, LMC, Dennis), and didn't see anything ressembling that part. Does anyone have a pic of what it looks like, and maybe where I might find one short of a wrecking yard?
Also, what's a good spary paint that closely matches the factory off white paint? I plan on spraying the sun visors and the rear view mirror also.
The door panels in my truck have no trim bordering the panels, are there supposed to be? They're the original metal basic door panels.
Thanks! :thup:
towtruckerfour
Re: Headliner/Door Panel Questions
Post by towtruckerfour »
Not sure about 67's but my two 70's just have a screw in the center and the edge trim screw. I think the door panels depend on which model you have whether it be custom, sport, explorer.I have a custom and an explorer that have just the metal door panels.
Troy
george worley
Post by george worley »
My headliner has a screw in the middle. The headliner started cracking around it so I put a flat washer between the screw and headliner. I painted it black to match the color of the dash and doors. the color of the truck is black with a dark red seat which I got years ago out of a 79 F100
i'll try and get a pic sometime soon. i am in pain right now and dont want to walk around very much.
MAK
Post by MAK »
My original headliner on my 72 was just held in place with a sheet metal screw similar to what was used around the side trim and a "cup washer". You can pick either up at any hardware store.
Montana71-F100
Post by Montana71-F100 »
The photo is from my 1971.
Jay's67F100
Nice! Thanks for the pic Montana71-F100! On my 67 there were 3 or 4 of those type of screws that held the headliner to the roof. No I know what to hunt down.
some trucks not all of them had or have a small wooden block under that screw. or somplace under there the scews goes into as well as into the metal brace.
TexasTruck72
Post by TexasTruck72 »
As far as a good spray paint that matches the factory off white paint, I used Rustoleum Satin White spray paint on my '72. I replaced the original headliner this summer and repainted the metal trim brackets at the same time. I found this can of rustoleum to match my truck's original cream/off-white color for the headliner brackets. You can find it at Lowes or Home Depot.
Jack
1943 Ford GPW Jeep(sold)
1972 F-100 Custom
1976 F-150 Explorer
1996 F-150 Eddie Bauer ed.
Jay's67F100
TexasTruck72 wrote:As far as a good spray paint that matches the factory off white paint, I used Rustoleum Satin White spray paint on my '72. I replaced the original headliner this summer and repainted the metal trim brackets at the same time. I found this can of rustoleum to match my truck's original cream/off-white color for the headliner brackets. You can find it at Lowes or Home Depot.
Thanks for the info TexasTruck!!! :thup:
