explorer bucket seats!!!!
Ok, so I just picked up these sweet explorer bucket seats from like a '97. And I really want to put them in my 1970 f100. Is there anyway this will work? It has all the electrical stuff working too.
Re: explorer bucket seats!!!!
Theres always a way to work, you can get the electrical to work too if you got the brackets. You just need to be trained in the fine art of welding.
I don't know how to weld. I was hoping i could drill some new holes and work with the bolts.JMcTurnan wrote:Theres always a way to work, you can get the electrical to work too if you got the brackets. You just need to be trained in the fine art of welding.
You could do that, but I don't like having to drill knew holes in the floor of the cab so I welded some brackets. But yea, do what you know what needs to be done for you to like it.
JMcTurnan wrote:You could do that, but I don't like having to drill knew holes in the floor of the cab so I welded some brackets. But yea, do what you know what needs to be done for you to like it.
So there is a good chance I can get these bad boys bolted in? Also, I want the mechanics on the seat to work i have the bracket attached, all there is is a possitive and negative wire, do you know how i can wire that up to make it work?
run a power wire to it from the fuse box side terminals and put a inline fuse in there.
Oh yea man, I hooked up electric seats in my friends 1940 chevy. So I know its possible.
total fail.
exactly. seat was practically touching the roof.JMcTurnan wrote:Uh howd you fail? Lol only way I could think is height.
Yea, I used to have bronco 2 buckets. Worked nice, but they didn't give much padding so I went back to a bench.
