Installing shoulder belts
91Bear
Post by 91Bear »
How do I make this hole bigger (since it is off-center)? I have some metal nibblers but I don't know if they would work. I don't have tin snips or a grinder. Is the captive nut fixed behind this rubber plug or will it move when I remove the plug? Is it generally threaded or do I need to tap it?
Re: Installing shoulder belts
you may have to run the bolt in there with some sort of impact or something. i have seen that problem before. the bolt may bend the cab metal out of your way enough to make the next good bolt go in. nikon4u 67 had the same problem with his drivers side botl hole. it was off center.
91Bear
Post by 91Bear »
I don't have an impact wrench.
70_F100
Post by 70_F100 »
Use a die grinder or small file to cut away a little of the sheet metal.
Then, run a tap into the threaded boss to make sure the threads are clean.
Using an air wrench will only destroy the threads if the bolt is not started straight.
yes never start a bolt with an impact. it always tears the threads up. try to get it started in the hole. and use what ever you have to turn it.
91Bear
Post by 91Bear »
A die grinder runs off of compressed air, right? Don't have an air compressor. Can you fit a grinding bit into a cordless drill?
they do make cut off wheels and grinding bits for drill and dremel tools also if you have one of those.
70_F100
Post by 70_F100 »
Fordman is right.
You can get a grinding bit to fit a drill.
rd100
Post by rd100 »
Mine was the same way on the driver's side when I installed my shoulder belts about a month ago.
I used tin-snips. It worked great, took about 2 seconds, didn't have to cut out much to give clearance to the nut. Then I just poked around with a small screwdriver to get the rubber that was in the nut.
It's threaded and captive.
91Bear
Post by 91Bear »
I thought tin snips might be too big to get under the edge of the metal.
phydeaux99
Post by phydeaux99 »
where do you mount the retractors?
that depends on the setup you get. but probably on the floor in place of the old belt unit.
austin
Post by austin »
wait so are you useing universal shoulder belts?
91Bear
Post by 91Bear »
Who me? I'm not sure I know what universal shoulder belts are. As opposed to Ford-specific?
austin
Post by austin »
i seen some sholder belts once that didnt say the application so i just figred they where univrsal belts
im just wondering what belts i shuold get
