License Plate Lights on my 67
Jay's67F100
Post by Jay's67F100 »
So I got pulled over a couple nights ago, for not having working license plate lights. And since it was on Friday nite after midnite, I got to do the whole song and dance of the CHP officer making sure I wasn't "under the influence". Which I wasn't, but I understood since he's just doing his job. In the end he let me go and just told me to get it fixed.
The original owner removed the stock bumper, and replaced it with a big diamond plate type bumper. The guy I bought it from removed that, and put an original Styleside bumper back on but didn't hook up the license plate lights. The lights are there, but the wires are cut. One white wire coming from each light housing.
I was looking over the wiring diagram, and I think I'm supposed to tap into the Brown wire?
wildcard
Re: License Plate Lights on my 67
Post by wildcard »
Correct. That should be your tail lights. Turn on your tail lights after you're finished and it should come on if the ground is good.
Jay's67F100
wildcard wrote:Correct. That should be your tail lights. Turn on your tail lights after you're finished and it should come on if the ground is good.
Thanks! I'll give that a shot. :thup:
i think you hook them up here in the rear harness.
SteveC
Post by SteveC »
yes there should be two plug in thingy's hanging down near the bumper.... my bumper i use to have on there didnt have lights and there was no holes for ones. I wonder what the law is on that instance then??
And the pipe bumper on their now doesnt have a light ... hmmmm
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
ive never seen a harness with 2 pigtails hanging off for those lights. is that one your cs?
SteveC
Post by SteveC »
nope my 67 has 2 one. 1 have nothing on and the other has the 5 red running lights
1967 f-100 4x4
Jay's67F100
I have to look again, but the last time I checked I didn't see any pig tales where you could just plug it in. The wiring has been altered, it looks like it was wired to tow something before. There's some cut wires too, a harness of 4 wires I think but I have to trace where it's connected to. I'll check it out more on my day off this week.
